15 years ago11.0 installation on Linux problems
Basically, I wanted to setup Dspbuilder 11.0 and MATLAB 11a on linux64-bit(debian5), so that I can use both standard block set and advanced block set. After installation, setting some envi...
14 years agoThe uname thing looks like it could be an issue. What distribution of Linux are you running?
If you have access you could try modifying /local/altera/11.0/quartus/dsp_builder/dsp_builder.sh At line 88, it says: if ; then
ADD_LIBRARIES=64
else
ADD_LIBRARIES=32
fi You could change -p to -m. (Assuming uname -m returns x86_64). If that doesn't work you could delete all the lines from the quoted section above except for the ADD_LIBRARIES=64.
