15 years ago11.0 installation on Linux problems
Basically, I wanted to setup Dspbuilder 11.0 and MATLAB 11a on linux64-bit(debian5), so that I can use both standard block set and advanced block set. After installation, setting some envi...
14 years agoWhat do the following commands return (typed in the same shell you started DSP Builder):
uname -p
echo $LD_LIBRARY_PATH
