15 years ago11.0 installation on Linux problems
Basically, I wanted to setup Dspbuilder 11.0 and MATLAB 11a on linux64-bit(debian5), so that I can use both standard block set and advanced block set. After installation, setting some envi...
15 years agothe first problem looks like a 64/32-bit conflict. DSP Builder 11.0+ on Linux should support 64-bit MATLAB (finally), but something seems broken. i'm not sure what libdinkum_alt.so is but its part of the Quartus installation. maybe you are using Web Edition (which would only have 32-bit .so). you might have to install 32-bit MATLAB so DSP Builder runs 32-bit, and references 32-bit Quartus .so
try: lmstat lmulil -a -c port@server i can't remember the whole DSP Builder feature code but it has 512A in it
