10 years ago10G Ethernet MAC Design example issue
I'm using Quartus II 14.0. I wanted to simulate the design example for 10G Ethernet MAC ip core. I'm following Altera Document for step by step procedure for 10G E MAC ip core Mega function user guide. when i run the do tb_run.tcl , the modelsim fails to simulate and it gives an error. ------------------------------------------------------------------------------------------------------------------------------------------------------------- # Top level modules:# altera_eth_10g_mac_xaui_eth_10g_design_example_0_e th_loopback_composed_mm_interconnect_0_rsp_mux# Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013# -- Compiling module altera_eth_10g_mac_xaui_eth_10g_design_example_0_e th_loopback_composed_mm_interconnect_0_rsp_demux# ** Error: (vlog-7) Failed to open library file "D:/Altera_working/altera_eth_10g_mac_xaui/altera_eth_10g_mac_xaui/simulation/mentor/libraries/rsp_demux/altera_eth_10g_mac_xaui_eth_10g_design_example_0_e th_loopback_composed_mm_interconnect_0_rsp_demux" in read/write/execute mode. # # No such file or directory. (errno = ENOENT) # ** Error: ./..//submodules/altera_eth_10g_mac_xaui_eth_10g_design_example_0_e th_loopback_composed_mm_interconnect_0_rsp_demux.s v(99): Verilog Compiler exiting# ** Error: D:/altera/14.0/modelsim_ase/win32aloem/vlog failed. # Error in macro ./tb_run.tcl line 32# D:/altera/14.0/modelsim_ase/win32aloem/vlog failed.# while executing# "vlog -sv "$QSYS_SIMDIR/submodules/altera_eth_10g_mac_xaui_eth_10g_design_example_0_e th_loopback_composed_mm_interconnect_0_rsp_demux.s v" -w..."# ("eval" body line 5)# invoked from within# "com" -------------------------------------------------------------------------------------------------------------------------------------------------------------- what could be the problem.?? Do i need to set ENV_VARIABLES for modelsim..? Please help me. thanks & regards Vinod Kumar1 Reply
Which design example that you are using? Is it QII generated or from Altera web?
