10 years ago10/100 Mbps Ethernet with MAX10 device (10M08DCF256I7G)
Hello guys, I need to design a cost sensitive solution for an embedded system using ucLinux. The solution will be basically an IP phone, so the SIP stack must be implemented. Since cost is...
10 years agoTalk directly to distributors (arrow) and Altera reps. They can usually get the price down significantly based on volume.
