12 years ago100 MB Ethernet solution for Arria10
Dear forum members, I read the Arria 10 documentation, but it is not clear for me if the device supports the 100 Mb ethernet signaling. If it does, what IPs support 100 Mb ethernet PHY and MA...
12 years ago --- Quote Start --- Dear forum members, I read the Arria 10 documentation, but it is not clear for me if the device supports the 100 Mb ethernet signaling. If it does, what IPs support 100 Mb ethernet PHY and MAC layers (for Arria 10 devices) ? What are the limitations ? Thanks in advance, Yaron --- Quote End --- Hi, Please go through the Triple-Speed Ethernet (TSE) for your requirements. Please find the below link, where they stated that Arria 10 supports 10/100/1000 Mbps TSE. Hopefully, you will understand once you finish reading TSE user guide. http://www.altera.com/products/ip/iup/ethernet/m-alt-ethernet-mac.html You can use based on your choice for PHY like RGMII or SGMII interface with in build Marvel PHY chip or External PHY chip according to your design.
