16 years ago1-wire (onewire) SOPC builder component
Hi, Project home: http://opencores.org/project,sockit_owm The source code is here: https://github.com/jeras/sockit_owm The GitHub version might be temporarily slightly ahead to the Open...
15 years agoHi Curtis,
The "Qsys IP search path" should point to the parent directory of the components. For example if you have many custom made components inside one directory, you have to add a single path. Do you plan to use UCOS-II, or simply HAL? I am looking forward to your progress. I have spent a lot of time writing and testing this code, but is is hard to find other developers willing to test it. Regards, Iztok Jeras
