16 years ago1-wire (onewire) SOPC builder component
Hi, Project home: http://opencores.org/project,sockit_owm The source code is here: https://github.com/jeras/sockit_owm The GitHub version might be temporarily slightly ahead to the Open...
15 years agoHi Iztok,
I got it to compile. It turns out that I didn't have the sockit_owm directory inside the project directory. This seems to make a difference even if the Qsys IP search path is set to the sockit_owm directory. Thank you for your help. I will proceed and let you know if I run into other problems. Best, - Curtis
