LCard2's avatar
LCard2
7 years ago
.qip and .sip generated files manually added to project . On compile entities in .qip not found. Before I start cutting and pasting modules into existing.v files, what's proper way to incorporate these PLLs? Details of transcript warnings below.
Warning (20013): Ignored 16 assignments for entity "IPpll" -- entity does not exist in design
Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_NAME altera_pll -entity IPpll -sip IPpll.sip -library lib_IPpll was ignored
Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_VERSION 18.1 -entity IPpll -sip IPpll.sip -library lib_IPpll was ignored
Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_ENV mwpim -entity IPpll -sip IPpll.sip -library lib_IPpll was ignored
Warning (20013): Ignored 317 assignments for entity "IPpll_0002" -- entity does not exist in design
Warning (20013): Ignored 16 assignments for entity "unnamed" -- entity does not exist in design
Warning (20013): Ignored 14 assignments for entity "unnamed_altclkctrl_0" -- entity does not exist in design
