LCard2
7 years ago.qip and .sip generated files manually added to project . On compile entities in .qip not found. Before I start cutting and pasting modules into existing.v files, what's proper way to incorporate these PLLs? Details of transcript warnings below.
Warning (20013): Ignored 16 assignments for entity "IPpll" -- entity does not exist in design Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_NAME altera_pll -entity IPpl...
LCard2
7 years agoPlease point me to steps to take to get IP instantiated, compiled, and run in simulator. As you see, the Quartus Prime Standard has no “Generate Simulator Setup Script” tool.
Thank you.
Len Cardillo
eMagin
[cid:[email protected]]
