LCard2
7 years ago.qip and .sip generated files manually added to project . On compile entities in .qip not found. Before I start cutting and pasting modules into existing.v files, what's proper way to incorporate these PLLs? Details of transcript warnings below.
Warning (20013): Ignored 16 assignments for entity "IPpll" -- entity does not exist in design Warning (20014): Assignment for entity set_global_assignment -name IP_TOOL_NAME altera_pll -entity IPpl...
LCard2
7 years agoHave built msim_setup.tcl with command lines in sopc_builder with ip-make-simscrpt. Can't find procedures to get these files to incorporate appropriate PLLs in "work" directory with HDL ... getting "failed to run ip-make-simscript" invoking modelsim from quartus...
