16 years agox86 code
Hi. Anyone knows if there exists any x86 HDL code? e.g. VHDL code for an entire 80386. If it includes surrounding memory/IO/x87 components code I will be :). If it is adjusted for a DE2-70 board I wi...
16 years agoThe better web site is :
http://zet.aluzina.org (http://zet.aluzina.org) There you can browse the latest source files, join the forum and help us to improve zet. the DE1 is currently the working target, there are some people porting zet to the de2 and de2-70. the de0 will be used when the vga frame buffer will be located inside the sdram .
