15 years ago
Writing and Reading Data To & From RAM
I am trying to create a RAM (which is of 32*4 size) using the Mega Wizard Plug In Manager. So there are 32 rows into which data of 4 bits long can be written. The initialisation of the RAM is successful. Now, in order to fill the data into the RAM's locations one after the other, I have created an FSM which has a counter running from 0 to 31. The counter value is the address of the RAM. Thereby data is written onto the locations of the RAM.
When i simulate this program on the software, I get proper results. But when I try to run this program on the FPGA, I need to change the input and output variables such as data, input and output to SW[3:0], LEDG, LEDR etc. After changing like this, I am getting errors on the Software. When I try to mend the errors and run the program on FPGA the output does not come correctly on the FPGA. So I try to write a single bit into each location into the RAM but in vain again. I have tried all kinds of tweaking but FPGA still does not recognise the RAM. The code for the program is:
module ram (SW,LEDG,LEDR,clock);
input clock;
input [9:0] SW;
output [9:0] LEDR;
output [7:0] LEDG;
`ifndef ALTERA_RESERVED_QIS
// synopsys translate_off
`endif
reg GrOp;
integer wraddress;
integer rdaddress;
wire FSMW, wre;
assign FSMW = SW[7];
assign wre = FSMW ;
reg Ready1;
reg [3:0] out;
initial
begin
out = 4'b0000;
rdaddress = 4'b0000;
wraddress = 4'b0000;
end
always @ (posedge clock)
begin
Ready1 = 1'b0;
wraddress <= out; // wraddress <= out;
rdaddress <= out;
Ready1 = 1'b1;
out = out + 1;
GrOp = Ready1;
end
assign LEDG = GrOp;
// synopsys translate_on
`endif
wire [3:0] sub_wire0;
wire [9:0] LEDR = sub_wire0/*[3:0]*/;
altsyncram altsyncram_component (
.wren_a (wre), // SW[5]
.clock0 (clock),
.address_a (wraddress),
.address_b (rdaddress),
.data_a (SW), //.data_a ([3:0] SW),
.q_b (sub_wire0),
.aclr0 (1'b0),
.aclr1 (1'b0),
.addressstall_a (1'b0),
.addressstall_b (1'b0),
.byteena_a (1'b1),
.byteena_b (1'b1),
.clock1 (1'b1),
.clocken0 (1'b1),
.clocken1 (1'b1),
.clocken2 (1'b1),
.clocken3 (1'b1),
.data_b ({4{1'b1}}),
.eccstatus (),
.q_a (),
.rden_a (1'b1),
.rden_b (1'b1),
.wren_b (1'b0));
defparam
altsyncram_component.address_reg_b = "CLOCK0",
altsyncram_component.clock_enable_input_a = "BYPASS",
altsyncram_component.clock_enable_input_b = "BYPASS",
altsyncram_component.clock_enable_output_a = "BYPASS",
altsyncram_component.clock_enable_output_b = "BYPASS",
altsyncram_component.intended_device_family = "Cyclone II",
altsyncram_component.lpm_type = "altsyncram",
altsyncram_component.numwords_a = 16,
altsyncram_component.numwords_b = 16,
altsyncram_component.operation_mode = "DUAL_PORT",
altsyncram_component.outdata_aclr_b = "NONE",
altsyncram_component.outdata_reg_b = "UNREGISTERED",
altsyncram_component.power_up_uninitialized = "FALSE",
altsyncram_component.read_during_write_mode_mixed_ports = "DONT_CARE",
altsyncram_component.widthad_a = 4,
altsyncram_component.widthad_b = 4,
altsyncram_component.width_a = 4,
altsyncram_component.width_b = 4,
altsyncram_component.width_byteena_a = 1;
endmodule
Please let me know how to overcome this problem in Altera FPGA.
    Thanks for the reply, JacoL. I checked the RTL schematic of the code on Quartus. rden_a & rden_b pins are both at logical 1 by default. The Quartus software I use does not have a signaltap feature.
    I have some other programs (for eg adder) on FPGA...they have all worked fine. Only this RAM program doesn't work. The FPGA does not recognise the format of the program somehow.
    you really want to enable the read_enable on both sides all the time? You can use the signaltap to see how your signals handling the RAM. I think this can help you to see where the problem is.
