Windows 10 driver support for USB Blaster ?
Yep, that worked for me. Thanks! Glad to hear Intel is lazy like my little company in not getting their drivers registered with Microsoft!
I'm having no luck installing drivers for a DE10-Lite demo board on windows 10.
I've tried two computers and both end with the exact same message:
"Windows found drivers for your device but encountered an error while attempting to install them", "A problem was encountered while attempting to add the driver to the store".
I tried one option for eliminating driver signing (command line) and tried the advanced restart settings suggestion above but that ended with a bricked computer and a call to IT to get a bitlocker key. I'm not trying it again.
Are there any updates to this problem?
- Fancellu5 years ago
2021, this is still the case. Astonishing that they ship drivers that will simply not work for 99% of win10 users
The drivers in Quartus 20.1 are unsigned
I attach screenshot of what my Windows 10 says
Doesn't even complain about hash, just says no.
Had to turn off driver signing enforcement, then worked fine via JTag- fdsa985 years ago
Yep that's exactly the message I get.
Specifically how did you disable driver signing?
https://www.technipages.com/enable-disable-device-driver-signing
Option 2.When you install driver after that, it will warn you and ask if you are sure.
I even went and bought another USB Blaster, thinking that mine was faulty!
Thanks Intel!!!
