Will serialization factor of 6 in LVDS serdes IP be supported in the future on Agilex5?
Agilex 3 and 5 SERDES are apparently limited to 4 and 8 deserialization factor. I'd assume for the time being that the restriction is in silicon and can't be overcome by software. See e.g. this previous discussion
Deserializers in Agilex 3 series | Altera Community - 324280
For x12 deserializer, I see an acceptable solution by using x4 deserializer, external 3x4 bit shift register and external PLL with FCLKx3 slow clock. Implementing e.g. x10 deserializer for popular 8b10b encoded links is more complicated, particularly when looking at synchronization logic. I'd appreciate an Altera reference design for 8b10b receiver with Agilex 3/5.
Regards Frank
Hi Frank,
If I understand your suggestion correctly and taking 100MHz as sampling frequency into account this also doesn't seem a possible option. The 100MHz sampling frequency results in DCLK of 300MHz (ref. timing in first post). Oversampling with factor 4 would result in 1200Mbps which apparently is not supported...
Any other suggestions?
Lieven
