Will serialization factor of 6 in LVDS serdes IP be supported in the future on Agilex5?
Hi Lieven13
As far as I am aware, there is a workaround available where you can utilize LE to implement the data conversion, but it is for factor 7.
May I know if you have contacted any local FAEs for this?
Aqid
Hi Aqid,
I have contacted local FAE for this a while ago. So far I did not receive any response.
I currently have the ADC interface implemented in logic using GPIO IP for DDR handling and this interface is working properly. I am able to fit 4 ADC's like this in FPGA, but then compiler starts complaining and I get fitting errors depending on the usage of signal tap signals and/or other logic that I need in my project. At this time I only need 2 ADCs so there is no big issue yet, but once I need to use all 4 ADCs on my board I will have a further look at this. One of the first things I will try is making use of the LVDS Serdes IP (factor of 4) what will result in 2x oversampling of the signals.
As Frank mentions it is a pitty that other (de)serialization factors seem to be forgotten on these new Agilex series as well as 8b/10b decoding.
Lieven
