16 years agowhy the twice compilation different?
I use the quartus ii 9.0 with the default configuration,nothing special. When the first compilation, i found some problems in one module, so i take some inside critial signal of this module to the...
16 years ago --- Quote Start --- yes, there are several timing violations on the criticle path. --- Quote End --- Hi, you have have to solve the timing issues before you can expect that the design works fine. What timing violations do you have ? Kind regards GPK
