16 years agowhy the twice compilation different?
I use the quartus ii 9.0 with the default configuration,nothing special. When the first compilation, i found some problems in one module, so i take some inside critial signal of this module to the...
16 years ago --- Quote Start --- Hi, it is not only a different routing. By routing the signals to pins your are changing the synthesis itself, because this signals could not removed ( if possible) anymore. Did you have timing violations in your design ( setup or hold ) ? Kind regards GPK --- Quote End --- yes, there are several timing violations on the criticle path.
