shubham963
4 years agowhy the output wave is showing blue line in questa-intel FPGA
hi ,
i am trying to generated a pulse for my converter. In Quartus everything is fine and i have seen the output waveform in digital oscilloscope. I want to see the waveform in Questa-Intel FPGA bu...
shubham963
4 years agoHi,
Expected behaviour of output aged will be 50khz pulse(for my case in oscilloscope i got waveform as attached) and for pin_name1 it should generate same clock in ouput which is 50Mhz (In oscilloscope it is coming sinusoidal of 50khz because of filters ) . Both outputs should be a pulse only, of different frequency.
