11 years agoWhy does my code not like the addition clock in to the always loop?
This is my very simple code. If i have a single clock going in to the always loop, i get very few warnings and when i simulate it, i get an output. If i add a second clock in to the always loop, as shown here. I don't get any errors but for some reason it doesn't like it and i don't get anything out. I do quite quite of few extra warnings. The clocks are generated by a PLL. I have a 50Mhz clock going in to the PLL and output 2 300Mhz outputs that are 180 degrees out of phase of each other. I'm using a Cyclone III EP3C25F324.module Pulse(input clk,
input clk2,
output reg out,
output reg state_var, //debug outputs
output reg counter);
parameter init = 4'd0,
run = 4'd1;
initial
begin
state_var<=init; //Straight in to Init
end
always @(posedge clk or posedge clk2)
begin
case (state_var)
init: begin
counter = 3'd0;
state_var <= run;
end
run: begin
if (counter == 2'd0)
begin
out<= 1'b1;
end
if (counter == 2'd1) //50% duty cycle
begin
out<= 1'b0;
end
if (counter == 2'd1) //Restart at 50% duty cycle
begin
counter <= 2'd0;
end
else
begin
counter <= counter + 1'b1;
end
end
endcase
end
endmodule Thanks3 Replies
Even of you do stimulate it, the problem will be synthesis. Registers in an fpga can only be clicked from a single clock. Also 300 mhz is about the limit of a cyclone.
What do you mean by the registers can only be clicked from a single clock? Are you referring to the always loop being entered or are you meaning the values within the registers can only be updated with one clock?
I thought that the always blocks would be entered when a new 'event' occurred. So when either clock has a rising edge, this would trigger the always block to run. I don't particularly see the difference between 2 clock inputs and 2 other inputs where the data is flowing in just as fast. I do know that verilog describes hardware - some times i just find it easier to talk about it as if it was software. I backed off the PLL so they outputted 20Mhz each, which 40Mhz is no where near the Max frequency. I still didn't get anything out of it. I thought this would have worked. How do people manage to obtain DDR operation? - Altera_Forum
In verilog, you are right, the always block will always be entered when you get an event on clk or clk2:
always @(posedge clk or posedge clk2) So it's perfectly legal Verilog. The problem is it will not map to anything on an FPGA, as they can only accept a single clock per register. Your code has to be translated to real hardware, so you need to bare this in mind. I suggest you output a 40MHz clock from your PLL
