    1.You should be also able to convert *.sof to *.pof by the Convert Programming Files tool
    what is the Convert Programming Files tool?
    2.I didn't selected "Use configuration device" in the Device and Pin Options/Configuration" tab
    As you are apparently using a subsription license, that includes the FFT core: Did you select "Use configuration device" in the Device and Pin Options/Configuration" tab?
    You should be also able to convert *.sof to *.pof by the Convert Programming Files tool.
    I don't get "<project_name>_time_limited.sof" file.
    but get
    E:/FPGA/cip90-c3/cip90-c3.sof file
    is right?
    thanks
    Did you get a "<project_name>_time_limited.sof" file. If you are using OpenCore evaluation for any IP cores, you will not be able to generate a POF file.
    Jake
    Assembler report for cip90-c3
    Sun Nov 01 00:51:58 2009
    Quartus II Version 9.0 Build 235 06/17/2009 Service Pack 2 SJ Full Version
    ; Table of Contents ;
    1. Legal Notice
    2. Assembler Summary
    3. Assembler Settings
    4. Assembler Generated Files
    5. Assembler Device Options: E:/FPGA/cip90-c3/cip90-c3.sof
    6. Assembler Messages
    thanks
    --- Quote Start ---
    we use EP3C55F780C6 in our design ,and use ip fft9.0,
    but generate sof file ,no pof file ,why?
    thanks!
    mail: [email protected]
    --- Quote End ---
    which Quartus version do you us ? In case your are using the Web-Edition the use of the FFT function is limited to 1 hour after programming the device.
    "Warning: Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed
    Info: Evaluation period of megafunction that supports OpenCore Plus feature can be extended indefinitely by using tethered operation"
    That is the reason why you can't generate a pof-file.
    Kind regards
    GPK
