16 years agoWhy can't generat EP3C55F780C6 pof file in QUARTUS9.0SP2
we use EP3C55F780C6 in our design ,and use ip fft9.0, but generate sof file ,no pof file ,why? thanks! mail: [email protected]
16 years ago --- Quote Start --- we use EP3C55F780C6 in our design ,and use ip fft9.0, but generate sof file ,no pof file ,why? thanks! mail: [email protected] --- Quote End --- Hi, which Quartus version do you us ? In case your are using the Web-Edition the use of the FFT function is limited to 1 hour after programming the device. "Warning: Megafunction that supports OpenCore Plus feature will stop functioning in 1 hour after device is programmed Info: Evaluation period of megafunction that supports OpenCore Plus feature can be extended indefinitely by using tethered operation" That is the reason why you can't generate a pof-file. Kind regards GPK
