14 years agoWhich boards support HIL in Matlab/Simulink?
I tried a self made one, but it shows in the Matlab Command Window No device found from JTAG cables. Make sure the DSP Development Board is attached and switched on :(:( Does it mean that I need a DSP Development Board to do HIL ? That would cost alot any alternatives? thanks in advance!2 Replies
--- Quote Start --- Assuming you're using HIL in DSP Builder, then any board with JTAG should work. Can you see the board in the Signal Compiler when you scan devices? --- Quote End --- I've figured it out, something is wrong with the JTAG chain,thank you anyway - Altera_Forum
