14 years agoWhich boards support HIL in Matlab/Simulink?
Which boards support HIL in Matlab/Simulink? I tried a self made one, but it shows in the Matlab Command Window No device found from JTAG cables. Make sure the DSP Development Board ...
14 years ago --- Quote Start --- Assuming you're using HIL in DSP Builder, then any board with JTAG should work. Can you see the board in the Signal Compiler when you scan devices? --- Quote End --- I've figured it out, something is wrong with the JTAG chain,thank you anyway
