16 years agoWhere to go from here? I need help.
I have completed my design, solved all the issues and it is function properly as I expected it. All of that was done on Cyclone III Starter board, and by using Quartus and other Altera tools. Now wh...
16 years agoIt would seem that at this point you are in over your head. You have a few options. You can either get someone else to do it for you / with you. Or you can spend the time to get your head above water. This would involve educating yourself about board design. You're not going to get that from the forum.
My suggestion would be to select a commercial PCB design package and take advantage of every training tool the vendor has to bring you up to speed. It's not going to happen overnight. With regards to the FPGA, you'll have to spend the time going through the datasheets and user's guides to get things right. You can always ask specific questions here about pull-ups on specific pins and such. Jake
