16 years agoWhere to go from here? I need help.
I have completed my design, solved all the issues and it is function properly as I expected it. All of that was done on Cyclone III Starter board, and by using Quartus and other Altera tools. Now wh...
16 years ago --- Quote Start --- I have completed my design, solved all the issues and it is function properly as I expected it. All of that was done on Cyclone III Starter board, and by using Quartus and other Altera tools. Now where I go from here if I want to move my design to be a real board and be able to sell it. With little research I thought about:- 1-Creating a schematic of the component used in the design. --- Quote End --- Yes. And check it with soldering to you "Started board" --- Quote Start --- 2-Create a BOARD from the schematic. --- Quote End --- PCB design. --- Quote Start --- 3-Send the board file to manufacturer to build it for me. --- Quote End --- Gerber files. --- Quote Start --- I don’t know the basics even for what “pull up” resistor needs to be connected here at this FPGA pin not to burn it, etc... --- Quote End --- Think that this is a spring, attached to 3.3, 2.5, 1.8, etc Volts. --- Quote Start --- Is there anything in Altera’s tools can use my working deign and create for my useful startup point? --- Quote End --- I'm not sure that Altera can help you in this area. But you can some of you ideas http://www.linear.com/designtools/software/ltspice.jsp
