MartinMaa's avatar
MartinMaa
19 hours ago
What is the difference between these two clear signals?
Hi, I’m currently investigating an issue. I’m using an FPGA SCFIFO to replace a 72V251 FIFO, with rclk = wclk.
I found that if I keep rebooting the device, my industrial camera occasionally shows image tearing. However, this does not happen every time, and my pixel clock is only 36 MHz, so I would not consider it a very high frequency.
Could I ask what the difference is between these two FIFO reset options?
  • Asynchronous clear
  • Synchronous clear (flush the FIFO)
1 Reply
  • sstrell's avatar
    sstrell
    All documented:
    https://docs.altera.com/r/docs/683522/25.1.1/fifo-ip-user-guide/fifo-synchronous-clear-and-asynchronous-clear-effect
