KK000's avatar
KK000
7 years ago
What I/O standard shall I use in the pin planner to use a differential pair signal in a FPGA bank connected to 3.3V to compile my project ?
I am connecting VCCIO of some FPGA bank to 3.3 V for interfacing FPGA with ADC and DAC, Can anyone tell me what I/O standard should I give in .QSF for Differential inputs and outputs in Cyclone V FPGA.
  • SreekumarR_G_Intel's avatar
    SreekumarR_G_Intel
    sorry for very late response , It is depends on the what is your VCCIO bank supply where it is DAC channel is connected .
    Thank you ,
    Sree
    • KK000's avatar
      KK000
      Actually what I want to know is If I am using I/O standard LVDS for DAC interfaced FPGA bank, does it supply 3.3V or 2.5V to DAC?
      Thanks in Advance,
  • Abe's avatar
    Abe
    For the ADC, the LVDS standard used is 1.8V LVDS, for this the FPGA interface should also match the same LVDS standrad and the IO Bank should be set as 1.8V LVDS.
    For the DAC, the LVDS input range is from 800mV to 1600mV, so setting the FPGA interface for the DAC to 1.8V LVDS should work fine for this device too .
    • KK000's avatar
      KK000
      ok thanks.
      Can I give "LVDS" as I/O standard for the fpga banks connected to 3.3 V power supply.
    SreekumarR_G_Intel
    Hello Kabilan, Can you kindly more elaborate on the ADC and DAC transmitter side ? It is also based on the IO frequency performance you would like to use. Also can I know which FPGA device you are using it ? Thank you , Regards, Sree
    • KK000's avatar
      KK000
      FPGA device I am using is CycloneV 5CSXFC6F31.
      ADC and DAC used is AD9653 and AD9783 respectively.
