sung_chulNew Contributor3 years agoSolvedWhat happens when the 1-port ROM exceeds the address? Hi- What happens when the 1-port ROM exceeds the address? For example, in the following cases data width = 8 data depth = 100 What is the value if you access address 101, 102 or ...Show MoreNurina3 years agoHi,It will just be X value.Do you have anymore concerns?Regards,Nurina
NurinaRegular Contributor3 years agoHi,It will just be X value.Do you have anymore concerns?Regards,Nurina
Recent DiscussionsRegarding Power-Up Sequence for Agilex 5Cyclone V SoC 5CSXC6 Series GXB Utilization and LimitationsHow to tell Quartus my Arria10 target system CLKUSR frequency is 100MHz?Agilex 3 PLL in Source Synchronous mode ?writing a word to cfm1 using on chip flash ip on max10
