15 years ago
what can I do to delay the source
I'm using the megafunction ALTDDIO as a receiver which requires the input data to be centered aligned to the rising and falling source clock. Unfortunely I have learned the source and data are going to be coming in edge aligned. I've been trying to find a way to delay the input clock by 90 degrees. I have looked into using the PLL, but because of the wide range of source clock (25MHz to 165MHz), the PLL won't be able to lock onto it so this is not an option.
Is there a way to delay the clock or data so that they meet the ALTDDIO requirement?
Your comment is much appreciated.
    165Mhz DDR might be do-able without a PLL, it's just tight. Depends on device and what-not. Note that if you can do that, then the lower rates should just work, as the edges move out. You'll want to add a multicycle to make sure you're doing "same-edge" capture. Assuming they come in edge-aligned:
    create_clock -period 6.060 -name fpga_clk [get_ports fpga_clk]
    create_clock -period 6.060 -name ext_clk
    derive_clock_uncertainty
    set_input_delay -clock ext_clk -max 0.5 [get_ports {data[*]}]
    set_input_delay -clock ext_clk -min -0.5 [get_ports {data[*]}]
    set_input_delay -clock ext_clk -max 0.5 [get_ports {data[*]}] -clock_fall -add_delay
    set_input_delay -clock ext_clk -min -0.5 [get_ports {data[*]}] -clock_fall -add_delay
    set_multicycle_path -setup 0 -rise_from ext_clk -rise_to fpga_clk
    set_multicycle_path -setup 0 -fall_from ext_clk -fall_to fpga_clk
    The multicycles are the most confusing part, but they basically go for same edge latching. This is good since the clock tree will be longer than the datapath, and hence will buy you some setup margin.
    Why don't you think the PLL will lock? It should, but you will just have to work a little harder. The ALTPLL_RECONFIG Megafunction can be used to program the feedback parameters of the PLL and phase-shift the clocks.
    If you have another reference oscillator clock, eg. 125MHz, you can use that to measure the frequency of the variable frequency incoming clock. For example, I have a design where I pulse a control line (for a ~100ms) and count the number of 125MHz clocks and number of reference clock periods during the pulse high time. Then with that I can estimate an external reference clock frequency. In my case, I am just confirming it is the frequency I expect. In your case, you would use the measured frequency to then determine PLL settings, and reprogram the PLL via the ALTPLL_RECONFIG interface, and check that the lock signal locks.
    Then you can pulse the phase shift circuits on the PLL and capture data. If you know what the data is supposed to be, then you can perform a sweep such that you get bad data, then good data (hopefully at multiple settings) and then bad data again. You then move the capture location to the center of the eye pattern.
    Take a look at the ALTPLL_RECONFIG function and see if it will work for you.
    Depending on the FPGA you are using, there are also delay elements in the FPGA IOEs. I recall seeing a program MORPHIO I believe ... yes, this document,
    http://www.altera.com/literature/wp/wp_morphio_reconfig.pdf
    where they used JTAG commands to manipulate I/O settings. If this scheme allows you to change IOE delays, and there is enough delay range to meet your timing requirements, then that might be another option for you.
    I would recommend the PLL option though, as that has direct support, and you'd likely get help if you could not figure out how to use that method.
    Cheers,
    Dave
    Aside from using time constraints (which I wouldn't recommend) I think using a PLL is your best bet, assuming the multiple clocks you are talking about are at known discrete frequencies.
    You can use multipliers within the same PLL to generate the derived clocks, specifying different phases as desired (you can have 5 different outputs with 5 phases and frequencies from the same PLL on the Cyclone II for example) Otherwise, you can use clock switching (mentioned in the Altera PLL Megafunction User Guide.)
