14 years agoWeb server using EPCS controller
With reference to the web server example available in Altera Wiki http://www.alterawiki.com/wiki/web_s...x_progress_bar (http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar), I tested th...
14 years agoWhat have you done to validate that your epcs_controller is functional? Booting from it will give you a reasonable degree of certainty, but I'd advocate running code from the memory test example on it as well.
Start there to rule out any strangeness with the interface itself, then move onto _very_ simple "Hello, World" HTML content...find out where things start breaking and you'll have a good chance at getting things to work. Cheers! - slacker
