15 years agoWeb Server example
Hi, With reference to the web server example available in Altera Wiki http://www.alterawiki.com/wiki/web_server_with_ajax_progress_bar, I tested the example project and it works fine ( it was t...
15 years agoHi abubaha,
Did you get any further with this, i have also attempted to put the zip file in epcs as i was hoping to remove the flash from our board. I encountered a number of problems. One of which is being unable to easily locate (Offset within EPCS) the zip file in the EPCS using the flash programmer as the epcs controller is only 2kb in size i cannot add an offset. I tried to modify the Address and then use the srec parsing to add this to the correct offset. I can send the file but still no dice on accessing the file. Any ideas or anyone else who knows what to do this would be great. Cheers Tim
