16 years agoWarning : Inferring latches for signal or varialbe
Hi all,
Am new to VHDL and this forum. When executing my VHDL code am getting following warning "Inferring latches for signal or variable "datain_mem" which holds its previous value in one or more paths" "Inferring latches for signal or variable "datain_reg" which holds its previous value in one or more paths" my code is library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity datapath is port( reset, clk, start: in std_logic; mainout: out std_logic_vector( 7 downto 0 ) ); end datapath; architecture struct of datapath is component controller is port( clock,GO,rst: in std_logic; wr,memdrive,aludrive,ld_x,ld_y: out std_logic; funct_in:in std_logic_vector(7 downto 0); addr: out std_logic_vector(7 downto 0); funct: out std_logic_vector(2 downto 0) ); end component; component memory is port ( clock,rst,wr,memdrive : in std_logic; data_in,address : in std_logic_vector(7 downto 0); data_out : out std_logic_vector(7 downto 0) ); end component; component alu is port( reset, clk, l_x,l_y,aludrive: in std_logic; xm,ym: in std_logic_vector( 7 downto 0 ); func_m: in std_logic_vector( 2 downto 0); aluout: out std_logic_vector( 7 downto 0 ) ); end component; signal address: std_logic_vector( 7 downto 0 ); signal wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s: std_logic; signal funct_s: std_logic_vector(2 downto 0); signal mainbus : std_logic_vector( 7 downto 0 ); signal datain_mem ,datain_reg: std_logic_vector( 7 downto 0 ); signal dataout_m,math_out,dataxout,datayout : std_logic_vector( 7 downto 0 ); begin Control:controller port map(clk,start,reset,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,address,funct_s); Mem: memory port map( clk,reset,wr_s,memdrive_s,datain_mem,address,dataout_m); Arithlogic: alu port map( reset,clk,ld_x_s,ld_y_s,aludrive_s,datain_reg,datain_mem,funct_s,math_out); mainout <= math_out; process(clk,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y_s,mainbus,dataout_m,math_out) begin if (wr_s = '1') then datain_mem <= mainbus ; end if; if (memdrive_s='1' ) then if (wr_s = '0') then mainbus <= dataout_m; else mainbus<=(others=>'Z'); end if; if (ld_x_s='1' or ld_y_s='1') then datain_reg <= mainbus; end if; elsif(aludrive_s = '1') then mainbus <= math_out; else mainbus<=(others=>'Z'); end if; end process; end struct; Can anyone pls help me resolve this issue.... Thanks in advance3 Replies
Hi all,
Thanks for ur answer. its works. i got some warning like Tri state node(s) do not directly drive top-level pins Is this warning matters or not... coz when trying to generate functional simulation netlist, am not getting the wave from file. Can anyone pls help me to resolve this issue... Thanks in advance.....:) :) :) - Altera_Forum
--- Quote Start --- Change the asynchronous process to a synchronous one. process(clk,wr_s,memdrive_s,aludrive_s,ld_x_s,ld_y _s,mainbus,dataout_m,math_out) begin if rising_edge(clk) then if (wr_s = '1') then datain_mem <= mainbus ; ..... .... ... --- Quote End --- and you can remove all signals except clk from the sensitivity list. - Altera_Forum
