16 years agoWant help in adding delay in Verilog,using Altera de2 FPGA
Asslam o ALukum Hey can any one help me, i added an delay but its not running on FPGA... please anyone help me out how to add delay that is executble on FPGA board Thanks
16 years agoAdding the# <delay> will give you a delay in simulation, not in hardware.
Depending on which FPGA you're using, you'll have IO Delay Buffers in the I/O Buffer. You should be able to find details by searching the relevant Device Handbook for "delay". The delay values should be defined in the Device Handbook's Datasheet section. Regards, Mike
