Voltage supported by EPM7032LC44-10
- 3 years ago
Your part number reference is for the original MAX 7000 series, which is 5.0V core and I/O only.
It does NOT support 3.3V or lower I/O voltage levels.OTOH the MAX 7000B series has multivolt I/O capability, and can support 3.3V, 2.5V, or 1.8V I/O using the VCCIO pin connection.
It does NOT directly support 5.0V I/O however, max VIN is something like 4.6V.Maybe you are asking about the MAX 7000A series. It has multivolt I/O that can support 5.0V, 3.3V, or 2.5V operation using VCCIO.
So if you are asking about EPM7032ALC44-10 instead then the answer is yes it can support 5.0V I/O.
