16 years agoVirtex-5 equivalent Altera FPGA
Hi all, I am planning to use Virtex-5 XC5VLX155T FPGA from Xilinx. It supports RocketIO GTP transceivers from 100 Mb/s to 3.75 Gb/s. Which is the equivalent Altera FPGA ? If technology node is ...
16 years agoTake a look at the Arria II X family.
Do not get confused by the Altera naming structure. In order to get the RocketIO function in an Altera part, you will need something with a "GX" in the name. Maybe the 125 or the 190 will do - it depends on the number of internal Registers or LE's you arte looking for. You could also look at the newer Cyclone IV GX family - it all depends on how much of what (LE, F/F, Multipliers, IO, Transceivers, Memory) you need. I hope this helps. Avatar
