14 years ago
VHDL/Modelsim bug?
Hello, i have two modules sending signal to each other, one module has the following code
when WAIT_REQ_DATA =>
        -- Wait for a requisition from the Goertzel module
        if req_data = '1' then
          calibration_state_next <= ASK_DATA;
          get_data_reg_next      <= '1';
        else
          calibration_state_next <= WAIT_REQ_DATA;
        end if;
while the other has this code
when WAIT_ENABLE =>
          get_sample_next <= '0';
			 if  data_ready_i = '1' then
			   state_core_next <= LOOP_PRINCIPAL_P1;
			        else
          state_core_next <= WAIT_ENABLE;
			 end if;
Everything seems ok and it works for 185 times... then it stops to work (when the data_ready_i goes to 1 my state doesnt change in the second module)
I made a change in my code to this:
when WAIT_ENABLE =>
			        else
			 end if;
And then we can see in the screenshot that in the 185th time my module needs the data_ready to be one for two clock pulses
There is absolutely no sense on this... why would everything work for 185 times and then stop? I am in the right state working for the pulse and the pulse happens...
any help is welcome
    Nope.
    Well, i registed the input and everything works fine now but i shouldnt need to register the input..
    As such it is perplexing without knowing fullm picture. However I note the change occurs when get_sample gows low. Do you have any conditions apart from if somewhere up the process
    It's like the IF isn't working, can't be more clear then IF IN = 1 change state
    and the IF is going to one.. seriously
    Both modules are recieving the same clock input (50 mhz) directly from the pin.
    Data_ready_in is an input that is connected in the get_data_reg_next from my second module
    when INCREMENT =>
            -- Increment signals for processing
            data_output_reg_next   <= acc_reg;
            data_ready_reg_next    <= '1';
    and it goes to zero one state after..
    how do you generate data_ready_in.
    if it is not generated on same clock you might get problems of delta delay or actual delay that is not visible in waveforms
