17 years ago
vhdl syntax error
hello,
here is part of my vhdl codes.
ce : in std_logic;
addr : in std_logic_vector (15 downto 0);
process(ce, addr)
variable gpio_enable : std_logic ;
begin
case ce and addr(7 downto 5) is --line 58
when "001" => gpio_enable <= '1';
when others => gpio_enable <='0';
end case;
end process;
when i compile th design, i got an error :
Error (10327): VHDL error at wb_io.vhd(58): can't determine definition of operator ""and"" -- found 0 possible definitions
Can anyone help me ??
    ce : in std_logic;
    gpio_enable <= '1' when (ce='1' and addr(7 downto 5)="001" ) else '0';
    I believe you want to concatenate rather than "and". Try this
    signal sub_addr : std_logic_vector(3 downto 0);
    sub_addr <= ce & addr(7 downto 5);
    case sub_addr is
    when "1001" =>
    you might as well just use a single combinatorial assignment
    Kaz
