16 years agoVHDL Strange Behavior
Hello, I need to calculate the average between 4 std_logic_vectors: "A, B, C and D". When I simulate my code in modelsim everything seems to be OK:cool:. But, When I test it in t...
16 years agoI suspect that you're trying to add together 4 inputs in a single clock cycle is causing the problem. Normally, it would be better to pipeline it, doing A+b and C+D in parrallel, then the next clock cycle add the two results and bitshift.
