15 years agoVHDL std_logic_vector Comparisons
What's the best way to compare std_logic_vector 's to zero in VHDL? I don't want to use conversion functions, create a std_logic_vector of "0"s, or do element-by-element comparisons.
15 years ago --- Quote Start --- I'm going to use AND_REDUCE() --- Quote End --- Yes, that's better. P.S.: I understood "What's the best way" is asking for a convenient way without writing too much text. VHDL is verbose enough anyway. For this simple reason, the original poster did not want to define compare strings and similar stuff. The compiler will convert any equivalent expression to anding all bits. P.P.S.: I completely agree with Tricky, that numeric quantities should use numeric types and also numeric constants.
