15 years agoVHDL robot design not working
Hello everybody I'm new in VHDL and I'm doing a project with DE2 board In the project I need to build a robot. My first step was to design a ASM and from that to take out the FSM which i...
15 years ago1. Warning (10631): VHDL Process Statement warning at Pwm.vhd(37): inferring latch(es) for signal or variable "Led", which holds its previous value in one or more paths through the process
2. Warning: Output pins are stuck at VCC or GND Warning (13410): Pin "Led[0]" is stuck at GND - for al of the code pins 3. Warning: Design contains 6 input pin(s) that do not drive logic Warning (15610): No output dependent on input pin "Rst" 4. Warning: Found 9 output pins without output pin load capacitance assignment Info: Pin "Led[0]" has no specified output pin load capacitance -- assuming default load capacitance of 0 pF for timing analysis 5. Warning: The Reserve All Unused Pins setting has not been specified, and will default to 'As output driving ground'. 6. Warning: No paths found for timing analysis
