15 years agovhdl querry
Hello Friends, I am new to VHDL and I have a couple of querries. Kindly help me out if possible - 1) If-else loop in VHDL. Now, what I understand is that VHDL code is synthesised into har...
15 years agoDear Friends,
Thank you for ur response. I am grateful. --- Quote Start --- VHDL code is synthesised into gates and registers. So if/elsif/else trees get converted to logic, and if it's inside a clocked process then this logic is registered. All signal assignments take place on every clock cycle. So in this case, write_req_2 is asserted 2 clock cycle after write_req_1. VHDL code is never executed. --- Quote End --- You mentioned if/else/elsif gets converted to logic. What exactly do u mean by that sir? Is it converted to registers and gates? What I understand is this - inside a process if there is merely an if-else loop it is a combinational design. But, when the if-else is inside a clock (i.e - if rising_edge(clock)..etc) then it is converted into a sequential circuit. Also why do you say that VHDL code is never executed ? How does one decide when to use combainational or sequential circuits ? Pls advice me sir. --- Quote Start --- A latch is a memory device. registers are latches. Latches are created when data is stored and all events on a signal are not covered. --- Quote End --- Why is it said that using lateches in VHDL is a bad practise ? Thank you very much indeed. Regards, Vinod Karuvat.
