15 years agovhdl querry
Hello Friends, I am new to VHDL and I have a couple of querries. Kindly help me out if possible - 1) If-else loop in VHDL. Now, what I understand is that VHDL code is synthesised into har...
15 years ago --- Quote Start --- Hello Friends, I am new to VHDL and I have a couple of querries. Kindly help me out if possible - 1) If-else loop in VHDL. Now, what I understand is that VHDL code is synthesised into hardware (gates/mux..etc) using a synthesizer. How is an if-else loop created in hardware? The -f-else is a sequential statement. Will it run/be executed at the same clock cycle or the next ? For eg - in the code shown After how many cycles is write_req_2 asserted ? Can anyone kindly explain this pls? Also, can if-else statements be used to generate/synthesize combinational circuits or only sequential ? Can anyone point me to a doc which shall explain in details how vhdl code is executed(order of execution/timing) and also how it is mapped into hardware ? --- Quote End --- VHDL code is synthesised into gates and registers. So if/elsif/else trees get converted to logic, and if it's inside a clocked process then this logic is registered. All signal assignments take place on every clock cycle. So in this case, write_req_2 is asserted 2 clock cycle after write_req_1. VHDL code is never executed. --- Quote Start --- 2) What is a latch ? fifo_o_addr_temp <= fifo_o_addr when fifo_o_addr_temp /= fifo_o_addr else fifo_o_addr_temp; --- Quote End --- A latch is a memory device. registers are latches. Latches are created when data is stored and all events on a signal are not covered.
