16 years ago
VHDL Protected type help
Hi everyone,..
I'm new in VHDL and FPGA, sorry for my lame question.
Here I have a project, and I thing I will need to use shared variable, here is the code I made :
--- Quote Start ---
library ieee;
use ieee.std_logic_1164.all;
-- Shared Function
package shared_function is
type sh_data is protected
procedure reset;
procedure set(signal new_data : std_logic);
impure function get_data return std_logic;
end protected sh_data;
end shared_function;
package body shared_function is
type sh_data is protected body
variable data : std_logic;
procedure reset is
begin
data := '0';
end reset;
procedure set(signal new_data : std_logic) is
begin
data := new_data;
end procedure;
impure function get_data return std_logic is
begin
return data;
end function;
end protected body sh_data;
--- Quote End ---
When I perform "Start Compilation" or "Analyze Current File" in Quartus II Processing menu, I got these error messages :
--- Quote Start ---
Error (10500): VHDL syntax error at shared_function.vhd(6) near text "protected"; expecting "(", or "access", or "array", or "file", or "range", or "record"
Error (10500): VHDL syntax error at shared_function.vhd(10) near text "protected"; expecting ";", or an identifier ("protected" is a reserved keyword), or "package"
Error (10523): Ignored construct shared_function at shared_function.vhd(5) due to previous errors
Error (10500): VHDL syntax error at shared_function.vhd(14) near text "protected"; expecting "(", or "access", or "array", or "file", or "range", or "record"
Error (10500): VHDL syntax error at shared_function.vhd(31) near text "protected"; expecting ";", or an identifier ("protected" is a reserved keyword), or "package"
Error: Quartus II Analyze Current File was unsuccessful. 5 errors, 0 warnings
Error: Peak virtual memory: 185 megabytes
Error: Processing ended: Mon Mar 22 20:38:45 2010
Error: Elapsed time: 00:00:07
Error: Total CPU time (on all processors): 00:00:01
--- Quote End ---
I use Altera Quartus II version 9.1 SP1 Subscription Edition and I have changed the VHDL input to VHDL 2008.
Really, I don't understand at all, someone help me, please tell me what makes it error,
Any kind of help will be greatly appreciated...
    --- Quote Start ---
    From what I read from The Designer Guide to VHDL 3rd Edition book, page 589, on the top page, it said that shared variable must be of protected types... how about that?
    --- Quote End ---
    This is true, but because it would break a lot of VHDL'93 code (because VHDL 93 allows shared variables the way I showed you) mode compilers just throw a warning rather than an error by default and let you do it (you can change all the pedant settings if you want so it throws an error).
    The basic guide is - dont use shared variables.
    Yeap, do not use shared variables.
    Sometimes, they just do not work.
    To see, if the 6 MHz clock is toggling, you can use synchronous edge detection. It's easy in this case, because every high or low state of clk6 will be sampled at least once due to the frequency ratio.
    signal clk6_s : std_logic;
    signal clk6_v : std_logic;
    signal edge_cnt: integer range 0 to 3;
    process (clk24)
    begin
    if rising_edge(clk24) then
      clk6_s <= clk6;
      clk6_v <= clk6_s;
      if (clk6_s XOR clk6_v) = '1' then
        -- clock edge detected
        edge_cnt <= 3;
      elsif edge_cnt > 0 then
        edge_cnt <= edge_cnt - 1;
        if edge_cnt = 1 then
          -- clock just stopped
        end if;
      end if;
    end if;
    end process;
    Tricky and amilcar =>
    --- Quote Start ---
    --- Quote End ---
    --- Quote Start ---
    --- Quote End ---
    Okay, shared variable should be avoided, thanks for your advice...
    Mr. FvM =>
    Your solution seem good, okay let me think and try it...
    Thanks for your help... :) I appreciate that... :)
