16 years agoVHDL Output help
I am using a Max 2 (epm240) to handle signals to control IR cameras in my lab. One of the output signals is supposed to go high when the board receives a certain signal. The problem is that nothing happens when it receives the signal. I have checked to make sure all pin assignments are correct as well as test another output on that pin which was successful. I also checked the input pins to insure they are receiving what they should be. Does anyone have any suggestions? Any help is greatly appreciated, thanks in advance. Joe PS below is part of the vhdl code. We are trying to activate the 'Internal Only' Mode (Bold font below). Address and Data (both recieved in parallel) are std_logic_vectors and the other input is Strobe. --handles imaging and start signals CommandStrobe: process is begin wait until (rising_edge(Strobe)); case Address is when "0000" => -- Select CAM Phase case Data is when "0001" => --Select CAM Phase 0 CamPhase<='0'; when "0010" => --Select CAM Phase 1 CamPhase<='1'; when others => -- do nothing end case; when "0001" => -- select system operation modecase data is
when "1000" => -- internal only
sysop<='0';
trig<='1'; -- start and sync imagers
when "0010" => -- int/ext
sysop<='1';
trig<='1'; --start and sync imagers
end case;
1 Reply
One more thing to add...
I assigned the pins using the pin planner in Quartus and not in the code (not sure how to do so in vhdl). Could this be a problem?
