16 years ago
vhdl help
In vhdl can we make an pin declared as "inout" to act as input or as output depending on certain condition.
entity rout is
port(
a : inout bit;
b : inout bit;
end rout;
i want "b" to act as output when a is input, and "a" as output when "b" is input.
I am using altera quartus 2 9.0 and i am getting this warning.
"Warning: The following nodes have both tri-state and non-tri-state drivers
Warning: Inserted always-enabled tri-state buffer between "a" and its non-tri-state driver.
Warning: Inserted always-enabled tri-state buffer between "b" and its non-tri-state driver."
what can i do to overcome this warning.
It may sound silly but i am a beginner and i need some help in this regard.
    Here is another confusing warning: Warning (15610): No output dependent on input pin "RXD".I have already used it like this "receiver PORT MAP (RXD,...,...); and "RSR<=RXD & RSR(7 DOWNTO 1)".How does this warning come from?
    It probably means that any logic you have got in there has been synthesised away. Often this can come from unconnected clocks or enables stuck at '0'
    Nice reply!Thanks!
    Actually ,there are warnings about some output pins are stuck at GND this happened maybe when I didnot give their inial values.You know I can't give each value for each of them.so how to prevent them from being stuck at GND or synthesized away?
    Without seeing your code, I cant tell you what the problem is.
    My previous 2 reasons are just the most common causes of the "output not dependent on inputs" problem.
    So do you know some common methods to solve it,like modify quartus settings ,the procedure or both?
    normally, its a problem with your code rather than anything to do with quartus
