16 years agovhdl help
Hi, In vhdl can we make an pin declared as "inout" to act as input or as output depending on certain condition. entity rout is port( a : inout bit; b : inout bit; );...
16 years agoIt tells you that you have asked for an io tristate but you are not using it.
So you must either use it or lose it. If you want it but it is not implemented then contention is inevitable...
