14 years agoVHDL gcd program
HI,
I written vhdl gcd program when i compile it gives an error. simulator : open source ghdl simulator command used : ghdl -a gcd.vhd library IEEE; use IEEE.STD_Logic_1164.all; entity gt is generic (width: natural); port(clock,reset,load:in std_logic; a,b : in std_logic_vector(width-1 downto 0); done : out std_logic; y : out std_logic_vector(width-1 downto 0) ); end gt; architecture RTL of gt is signal A_New, A_Hold, B_Hold : std_logic_vector(width-1 downto 0); signal A_less_B : std_logic; begin Load:process(clk) begin if rising_edge(clk)then if(Reset='0')then A_Hold <= A_Hold; B_Hold <= B_Hold; else if(load = '1')then A_Hold <= a; B_Hold <= b; else if(A_less_B='1')then A_Hold <=B_Hold; B_Hold <=A_New; else A_Hold <=A_New; end if; end if; end process Load; begin sub:process(A_Hold,B_Hold) begin if(A_Hold>=B_Hold)then A_lessthan_B <= '0'; A_New <=A_Hold - B_Hold; else A_lessthan_B <= '1'; A_New <= A_Hold; end if; end process sub; out:process(A_Hold,B_Hold) begin if(B_Hold=(others =>'0'))then Done <='1'; y <=A_Hold; else Done <='0'; y <=(others =>'0') end if; end process out; end RTL;2 Replies
Thanks..i wil try it..
What errors do you get? I see two potential problems:
You can't directly compare std_logic_vectors. I recommend to use the ieee.numeric_std library and the unsigned/signed types. Then you can directly use the comparison operator.if(A_Hold>=B_Hold)then
filling an array with "others" only work in an assignment, and when the destination has a know size. You can't use it for a comparison either. But if B_Hold is an unsigned/signed then you can compare it with an integer instead:if(B_Hold=(others =>'0'))thenif(B_Hold=0)then
