Kris4
3 years agoVHDL Counter
I'm trying to make an automatic 7-bit up and down counter. I want it to be in a loop. Let' say it counts from zero to 128, then back to zero, and so on . Is it possible to make a counter that ...
- 3 years ago
Not a fan of schematic design, I always recommend users to use verilog or VHDL to design their project.
Anyhow, you might need to alter a bit of the vhdl template by removing the min_count and max_count. And define the range in the vhdl design.
So that when you convert it into the bdf, it will shown as q[7..0] instead of q[mincount...maxcount]. I guess bdf only recognize it when it is in number.
Took some time to figure it out and attached here a working design with range 40 to 140 so you can check it out.
Richard Tan
RichardT_altera
3 years agoDo you have further question in regards to this case?
Richard Tan
