VHDL Counter
- 3 years ago
Not a fan of schematic design, I always recommend users to use verilog or VHDL to design their project.
Anyhow, you might need to alter a bit of the vhdl template by removing the min_count and max_count. And define the range in the vhdl design.
So that when you convert it into the bdf, it will shown as q[7..0] instead of q[mincount...maxcount]. I guess bdf only recognize it when it is in number.
Took some time to figure it out and attached here a working design with range 40 to 140 so you can check it out.
Richard Tan
Great It almost helped . I just wonder if it is possible to make it loop itself no matter of the inputs . So its' a closed cycle. 40->140->40 and so on. Nonetheless thanks for helping!
